dragstews
- Mar 27, 2024
- Belleview Florida US of A
- Jesse
- Body 1954, frame 1975
- R-100
- 406 ci SBC
Found a out of the way spot to mount the TPS ..
Carb is looking kind of busy ..
Not sure it's needed, but been thinking about doing a fast idle solenoid .. ?
Been giving some thought on how to go about doing this ..
Since the return springs been relocated to the front of the carb. the solenoid is going to be mounted in the spot where the springs use to be ..
I'll need to make up a bracket to mount to the intake bolts ..
I'm thinking the solenoid might be overkill .. ??
With this motor being a hoss and using a 508 compressor that doesn't require as much grunt as the older compressors did, may not need the fast idle solenoid ??
But ...
Would be much easier to make the bracket and do the fit with having the motor on the stand than being in the truck ...
Once I get it running and see that it's not needed, can always delete it, just two bolts and one wire to contend with ..
.. Seeyabye type deal ..
