Steering column bearings help
Fri00
PA
Shaun
N/A
I’m rebuilding my steering column and cannot locates replacement for the upper bearing and I searched everywhere I can think. The column is a non tilt for standard transmission out of a 1982 with manual steering. From what I can tell is the most basic column available for that year. Everything I seem to find is for tilt columns or for automatics. Anyone know of a source?
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Closest I can find is here:
This assumes the bearing is the same between a 3 speed and an auto non tilt.
Pricey little devil - Brg14 at -$113 ...
:eek:
legopnuematic
Licensed Junk Dealer
MO
Spencer
3 on the tree or 4 speed?
This is what you need for a 4 speed-
Still available from AC Delco
Fri00
PA
Shaun
N/A
Thanks, I’ve been searching for the bearing for a 4 speed.
Hard
