Another seat belt question
pbcasterlin
K10 Stepside
I am slowly getting the interior back together and am installing seat belts I got from LMC.
The shoulderd 1/2 x 13 pillar bolts...did the have a spacer with them ? If they did I put them somewhere I was sure I would remember lol
pbcasterlin
K10 Stepside
Even better would be if someone could post a picture of the shoulder belt bolted into the "B" pillar with the plastic cover removed. I just want to make sure I am not missing anything.
Torrey
Tulsa
Torrey
LS
I think I ran into the same issue as you using the LMC three point belts. The hardware they send with the retainer was much smaller than my factory bolt. I used the factory bolt, but there was about a 1/4" gap between the belt "triangle" the head of the bolt and my interior trim. I ended up using a rubber grommet just to keep it from rattling.
zulander
Indiana
Edward
c30
Nice call on the rubber grommet, will help keep your sanity.
Hard
