Door Seal to big
RvVern
Boston NY
k20
LS
I installed a new door seal from LMC because the top of my door seamed to leak some air and I thought a new seal would do the trick but the new seal caused a new issue, I have to slam the door real hard to get the door closed where the old seal it closed just fine , So my question is where can I find a thinner door seal so my door closes easier ? I threw my old seal in the trash or I would have put that back on, Thanks in advance
Octane
Atlanta
Eddie
If it's the correct seal it needs to break in over time.Or you may have to adjust the door striker.At least until it does break in.
RvVern
Boston NY
k20
LS
I put it in 4 months ago thinking it would break in but its not ?
fast 99
Spokane, Washington
How squeezed is the weatherstrip on the hinge side? Had the same issue, due to manufacturing tolerances [or lack thereof] one of mine was very tight and hard to close. It's been a year now with the door shut most of the time. It has finally come out of it.
That's totally normal. I put new door seals on mine 2 years ago and still have to shut mine harder than before. Completely worth it for the better seal/less wind noise IMO.
Scott91370
Burleson, Tx
Scott
Sierra1500
3 year old seals here and still slamming doors. I did adjust the striker to help some.
RvVern
Boston NY
k20
LS
the door seal measures 1/4" or thicker, after shutting the door sometimes I have to readjust the mirro
Autocar
Clark, CO
Mark
K25 VIN, but it's a 1 ton
Me too! Just replaced about a month ago and now slamming doors. I'll put up with it for benefit of less wind noise.
87gmcburb
Don
GMC Sierra Classic Suburban
The seals from LMC, Classic etc... are all aftermarket and fit poorly. If you are looking for actual OEM fit you need to contact Mr A' Chevy truck parts. HIs name is Jon Addington and he is the only place I have ever found actual OEM fit. He uses NOS seals and has them reproduced, this is as good as you get other than finding your own NOS stock or making them from original tooling. I have no affiliation with him only being a customer. I believe he is located in the Pacific North West but ships throughout the US. His number is 425-422-7345, or search Mr As/Jon Addington on FB.
I tried 3 different seals on my 87 burb barn doors and each one fit like crap until I found this guy. The new fit is slightly tight but settles in quickly just like the original.
Octane
Atlanta
Eddie
Spray it down with wd40 or lithium grease and try it.Or adjust the door.
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
^^^ This
I was going to suggest lubing the weatherstrip (especially at the hinge side) with something. I smeared a thin layer of Vaseline on the door where it makes contact with the seal to get my doors to shut at all.
RvVern
Boston NY
k20
LS
So I bought a 20’ door seal from Amazon and installed it and it’s a perfect fit for my door, and for $21.00 it’s a great deal, thanks for all the suggestions
Wazzabie
WA
Wazzabie
The aftermarket door seals do not fit like the originals. Also the aftermarket door seals do not look like the originals. I have some NOS door seals and they fit without having to slam the door. The aftermarket door seals are too big.
Cemack
Alberta Canada
K15
I was slamming mine fairly hard after putting in new LMC ones. I then put some pex pipe around the striker and it is way better. Then new striker had a piece of plastic around them from factory. If your striker is missing the plastic, try the pex pipe trick
Blazerbiker
Rifle CO
Stephen
K5, actually a Jimmy since it's a GMC
504in
On a single cab, rolling down a window can be a thing too. The cabs aren't vented (or not vented well enough) and it makes it harder to shut the door. It's also a pain to crack the window to shut the last door. Installing some sort of cab vent could be a good idea.
aultinator
