EGR bleed solenoid
Trucksareforwork
Spartanburg SC
Geoff
Maybe there are different kinds, but the egr bleed solenoid on my 85 305 w 700r4 activates when tcc is locked and bleeds vacuum off the EGR. It doesn’t add vacuum it releases it.
This was done (to my knowledge) to allow for a slightly richer mix when the converter is locked to avoid pinging when in low RPM / lean mixture / high vacuum situations. Deactivating EGR during this scenario allows for richer fuel / air mix.
Mine looks like the one posted from Amazon, not like the original poster’s.
@Trucksareforwork you are right. I learned some thing today ,thank you, I only knew of pulse width modulated ones but turns out there are some that are just on off. It didn't even click in my brain these trucks are dinosaurs,not state of the art. you are correct this application it is an on/off, it kills the egr signal when the torque converter is locked.
Trucksareforwork
Spartanburg SC
Geoff
Tried to find a pic of mine on my phone and this is best I can do.
The solenoid has a pigtail on back and two vacuum inlets. One side goes to the back of the carb (just a dump to atmosphere on the q jet) and the other is fed by ported vacuum from a tvs in a stock config.
My truck’s vac diagram shows how it’s set up on the vacuum side.
I think this was just another band aid to help with the significant ping/detonation issues the 305 has.
consti2tion
East Texas
Cw
C20 Suburban
I know this is an old post, but if anyone is looking for one of these I actually have a NOS one. Just shoot me a message.
jw23655
