C50 to C10 dash and cluster interchangeable?
montes57
Long Island, New York
matt
R30
apologies if this has been covered. I have a line on a interior in a 77 C50. I have a 77 C10 custom deluxe. My dashpad is horrible. C50 although shape looks slightly different doesnt have one crack. Also the cluster gauge needles on C50 are bright in color where as mine are beat,sun faded. Heater controls seem the same, are they? Lastly i was a fan of the old school big steering wheel. thought it would look cool in my C10. Practical as well since i dont have PS. Figured i would check with you guys before i get the ball rolling messaging this guy on MP. also what would be fair market value?
montes57
matt
R30
ehh. i zoomed in on dash. looks like ignition key goes in left of steering wheel on dash? pics posted are terrible
carfanatic63
Houston
Austin
C15 SWB
I think the guage cluster is interchangeable with some repinning of the harness. Doors should swap fine too. Not sure about anything else
CheemsK1500
K1500
Most components should be the same on the dash. There are some c50 specific items like air pressure guages on air brake trucks, but most other guages should be the same or similar enough to work in a small truck with some minor modifications.
montes57
matt
R30
thanks guys. i notice alot of these old work horses rotting away in fields and on marketplace. figured it might be a untapped resource.
TPISly-C10
Boucherville QC Canada
Sly
C-10 shortbox
LQ4 6.0L
i made my own with both C50 and C10 cluster! :)
Cyrillious
Toronto
Cyril
K10 Suburban
I saw one of those workhorses. Like you mentioned the difference is the bottom left hand corner using the air brake gauge. Too bad there isn't an rpm gauge to fit in that air brake spot!
montes57
matt
R30
im sure i can make it work, no clue what to do with port for ignition switch and choke on c50 cluster
Turbo4whl
Downingtown, PA
Wayne
I believe that the 0-4000 RPM tach would be for a diesel engine. The 366 and 427 tall big blocks gassers would have a 0-5000 RPM tach.
CheemsK1500
K1500
At least you have a nice place for a quartz clock.
ldmyers3195
