SirRobyn0
- Dec 6, 2019
- In the woods in Western Washington
- C20
Thanks to @AyWoSch Motors I finally have a set of running boards for my truck. These are a used set off a squarebody, they are extruded aluminum. Looks like there will be a little tweaking to straighten up the edges which I can do no problem.
First question: There is rust staining which I assume I can clean up with Lacquer thinner?
Below: A picture of my truck from a recent feed haul. Obviously the hoop step will go away, but I'm kind of throwing around the idea of painting the running boards black. What do you think? Good idea or bad?
So on the paint thing, I'm just throwing around the idea right now and will likely clamp the boards up after cleaning them up to see how I feel about the aluminum color. My biggest concern, if I do paint them is keeping the paint on them. My only method of painting will be rattle can, but I'm thinking it's not the best idea because I'll wear the paint off where I step in short order and every rock that hits it will chip paint away. What do you guys think?
Thanks!
Thanks!
