BearKing
- Apr 13, 2022
- Black Hills
- Bear
- K10
I have to ask a stupid question. I have my valve covers off on the 350. They leaked bad ( just got the truck a few days ago) Years ago I took a points distributor and ground the gear off and modified the top to use as a pre oiler. Today I used it and could get an easy 40 lbs of pressure and even hit 60 when I used high speed on the drill. No oil was coming out of the rocker arm tips from the push rods. That is correct, right? Due to the motor not turning over the rods won’t fill up with oil and dribble down the rocker arms? When the engine is cranking the the oil is pushed from the lifter through the rod to the rocker tip? Is this correct? Please help an idiot. Thanks fellas in advance.
