Doppleganger
- May 24, 2019
- OH-MI: Just like it sounds
- Chris
- K20
Here is my front axle I waited 9+ months to get.
Overall its ok, but not impressed with a couple areas. Clown didn't realize the dust shields needed to go on first, so I get to pull the spindles. Meh. Another thing was he pressed in 2 types of upper ball joints - one side is a Moog (as usual, Moog wasn't smart enough to put the correct part in the correctly labeled box 2x in a row), so he put another brand in the other side. He didn't realize the second brand had a 90 degree zirc fitting, so it was pressed in almost too far ccw to get a zirc in the hole. Guy who was supposed to do this axle retired from Dana (40yrs) and does them in his sleep....but of course he had to have some surgery so this slug did them instead. Not impressed for the time and money involved, but for the area we are sentenced to live in, its as good as it gets.
Anyways.....I want to remove the 2 upper ball joints and replace them both with 90 zircs properly positioned so I can grease them from time to time. This FU will never be easier to correct than now.
Since my spindles are coming off, I believe I have to pull the axle to get the ball joint out? QUESTION: will that damage the new seal that was just put in?
Thanks.
Thanks.
