78C10BigTen
- Apr 12, 2017
- pennsylvannia
- Ted
- C10 BIG TEN
Wish mine was that nice!!!!
I got the AEM 30-0300, so far I like it, I Have it kinda set up so I can plug it onto the cigarette lighter deal so I can swap it from truck to truckWhich Wideband did you install?
You must be registered for see images attachThis is where I am today, a year into this project.
Once it was torn down and cab gutted, it needed floor pans and many patches in the fire wall and a lot of cleaning. All new wiring harness from American Auto Wire, dash and heater/AC boxes refurbished. There have been so many little things that have been replaced, fixed or modified to make this swap work I can't even begin to list them all. I am glad I took a lot of pics. When I started this I thought I would be posting daily pics and updates, but as anyone with kids will tell you, life happens.
Quick question, Do you remember how you positioned your motor mounts when you installed the engine, and which motor mounts did you use on the engine side? I have stock clam shells with new bushings and Dirty dingo mounts just curious about placement!
I used ICT billet mounting plates using the factory location holes. Used factory clam shell but had remove the bump in the center. Hope this helps.
How many O2's does this setup have?
