Frankenchevy
Proverbs 16:18
- Jan 3, 2018
- USA
- Jeremy
- Square
- CUCV
- Small
I’m doing a little tinkering on the truck this evening for the first time in a couple weeks. I’m torquing everything on the suspension now that the truck is bearing weight on all fours. I have ORD bushings all around. The bushing in question is the main eye of the front spring. The bolt on the driver side had to draw the “cup” in quite a bit before reaching 75ft-lbs.
so I looked at the passenger side and this is what it looks like with the bolt snugged hand tight before putting a wrench on it:
There is about a 5/32” gap. Anyone pay attention to this when installing ORD’s HD front shackle/bushing kit? Would the experts out there recommend putting a washer on either side of the bushing? Truck has stock K30 springs...
Thanks!
Thanks!
