AC Compressor Constantly Running
Kilian
Wisconsin
K
C2500 on its way to a K2500
I was charging the AC system on my 83 GMC. System was empty so planning on putting in about 80% of the recommended R12 charge. Using 12 oz R134a cans. On my third can I noticed the compressor was no longer cycling, just running constantly. Using manifold gauge set but didn't notice any huge difference in the pressures. Is the pressure switch on the receiver/dryer the only control for cycling the compressor?
gmbellew
Kansas city
glen
suburban 1500
low pressure switch only. if it is really hot and humid, I dont know that it will cycle...
Kilian
Wisconsin
K
Thanks for the reply. What shuts off the compressor and prevents things from freezing up or high system pressure?
gmbellew
Kansas city
glen
suburban 1500
the low pressure switch serves that function. it is on the drier.
YakkoWarner
Central Texas
Wolf
R2500 Suburban
In a properly working system, as it gets cold the pressure on the low pressure side should decrease, and then the compressor will cycle. If the system has a problem that doesn't allow it to cool down enough that might not happen, which is why newer systems also have a high pressure cutoff on the compressor. My truck doesn't have a high pressure cutoff either so it stays on. My system is not properly working so builds up too much on the high side, or I have to remove a very small amount of gas and then it short cycles. If its getting good and cold, with the pressures on-spec with the gauges, its probably working as designed.
73jacobs
