K10 NEED LONGER WHEEL STUDS.
mavtricks71
az
mike
IF anybody has ever put longer front studs in there own k10 please chime in, I cant find original 7/16 style wheel studs aftermarket anywhere...I need them 1/2 longer. ORRRR if anybody has pressed in larger diameter 1/2 inch wheels studs please let me know.....
mavtricks71
az
mike
Ok we got it figured out....a differential company locally is installing longer wheel studs front and back to better accommodate my aftermarket wheels.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Mind sharing the specs of your wheels that made you need longer wheel studs?
I'm still running the older 7/16"-20 style wheel lugs that were factory for my truck. I ordered the wheel studs from Rock Auto.
mavtricks71
az
mike
I bought 15x12 mickey Thompson classic 3 wheels.
K10eddie
Connecticut
Ed
I have the same wheels, and also need to get longer studs. Mind sharing the part number or any info?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I used studs for a 68 Corvette on the rear. They fit perfect and are easily available. Fronts I can’t help ya on them.
Big red square
El Paso
Lewis
Same boat what did you guys end up doing?
jpowell74
binghamton NY
josh
5.7L
has anyone come up with a solution yet? I can’t find a lug stud that works
Bennyt
Surprise
Ben
ARP has a good selection
1979k10
Las Vegas
Dirty Dave
Dorman 610-126 if you are upping to 1/2” diameter.
Moderator
Nevermind... that's not the part # I was thinking of. But the knurled area looks like it may not reach the hub? Does the rotor fit snug with those studs?
1979k10
Las Vegas
Dirty Dave
samelthecamel19
