I can try that. I have a 2 5/16 ball on a stinger not doing anything. I also have one of those pipe fixer upper gizmos with three rollers in a triangle with a handle screw that sets the diameter I could use to roll out the one end of the muffler that has the ding in its end. There are options. I wanted to be able to open the ends of pipe just to the others O.D. for slip fit without going the hydraulic expander route.
Or go like 78 C10bigten did with band clamps. Welding seems to be optimum so I guess it will end up how it ends up when the time comes.
Good idea Ricko, thanks!
To make sure we are on the same page. Use a ball smaller than your pipe.Ball inside the pipe hit the pipe above the ball with the hammer, the metal below the hammer will flatten and stretch slightly, stretch,stretch, stretch. A little here a little here, a little here, all the way around and id/od will have to grow. A little heat would help. A vice and round stock would be a better anvil. But most people have a reciever and ball.
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
Yup, I'm going with the 3" exhaust since I've already acquired the mufflers and cats in said guage. 2½" is probably the better choice, but I'm already at 3, so...
I have a vise and some 2 something heavy pipe I can try too. Never was much of a body guy, was always an under hood/under car tech so it won't hurt me to learn something like that.
I will experiment on some scrap pipe to get my technique down and certainly won't be banging on the cats to size them; size their inlet/outlet pipes instead. Thanks for the nudge Rick. Some long tubes (in the parts pile already) and I'm off to the races. ;)
Marine Corps Moderator
Got a mini heat gun of the wire connectors that have the soder in them. Got a box of wire connectors. Insulated wire/tube hold downs. A three piece set of folding pop up parts holders for father's day.
legopnuematic
Licensed Junk Dealer
MO
Spencer
Mom and Dad got me this Huot drill dispenser at a garage sale for $5.00.
I put my carbide drill collection in it.
KSSB
Kansas
Ty
Custom Deluxe, Silverado
250 I6, 6.2 Detroit
That's a heck of a score!
I got the same 2 first items, I love them. I use the mini u shaped deflector shield on my mini gun.
legopnuematic
MO
Spencer
Thanks guys, it’s fun helping spend other people’s money… :)
It can be a steep and slippery slope with those drill dispensers. Start with a fractional one, then decide to get number and letter ones, then realize how many of those you might be missing, so then purchase bits to fill them in, etc.
I do have one of the Vevor ones that I use for my high speed steel fractional drills, they are pretty decent for the price, the labels are kind of meh, but that’s easily enough solved.
Moderator
I've got a couple of those drill dispenser cabinets (older), I didn't even know that's what they were for, lol. I keep npt fittings, compression fittings, adapters, seatbelt bolts and other similar small items in them.
Didn't get but wanted to share:
I use these. They work great. Walmart has the tool in the video for $6.00 looks like a gimmick to me. Also I'm pretty sure mine are Irwin I've had them 30? Years and on a rack not original packaging. Now lots of companies make them, cheap. I can't say they are as good as mine but I'd think a midpriced set would probably be alright.
Sad Sack
Nebraska
Goober
C15
hauto85
