Cruise Control Linkage Needed for an 87 tbi
Hunter_Michael
Lower Alabama
R10 Short Bed
How come these linkages are so hard to find??? Does anyone know where I can get one? Thanks
vr1967
Mississippi
Virgil
k1500
6.2L turbo
I’ll try to remember to look tomorrow. Believe I still have the cruise stuff from an 89 Blazer I parted
Scruffy49
Law Enforcement Navy
Rosemark TN
Jeff
C10 swb
4.3L
If a 92 rod would work, have 1 I don’t need. Engine is going carbed and back into a Squarebody (1979 block/heads).
vr1967
Mississippi
Virgil
k1500
6.2L turbo
This should be it. About 8” long. Adjusts by hand, so not frozen up.
@Hunter_Michael
87SQRBDY
Army
Fayetteville, NC
Josh
5.7l 350
Does anyone know where to find the cruise control vacum setup? The little tab on mine broke and had the motor wide open until I pulled the rod off then taped it back on, but not using cruise control any time soon. Thanks.
Hunter_Michael
Lower Alabama
R10 Short Bed
From what I understand they don't make that part anymore so you would have to find a used one, best place is Ebay. Search GM Cruise Control Servo and several will pop up. Corvette, Buick and several other years and makes used the same one. I just got done rebuilding mine to get it to work again. The filter inside had disintegrated and had to be replaced. There is a youtube video on how this is done, It was pretty easy.
mo4154
