Castor shims
Ontheboulder
colville,wa
greg
gmc sierra classic v2500
just an update on the castor issue. took to Les schwab for alignment check. definitely need some castor work. the shims are on the wrong side of the axle - front ,should be to the rear., minor lower ball joint loose and the toe in is good according to the readout they gave me. I found out that if Les schwab loosens the u-bolts to change the shims they have to put new u- bolts on!! Company policy they said. Castor setting is supposed to be around 7- 8 degrees positive mine is negative 4.5 degrees. that should make a difference, I hope. thanks for all the input, I will let ya know how it drives once i get the shims done!!
blue10
