Picked up a new tow rig
iansane
Tacoma, wa
Ian
c30
I started a little endurance race team with some friends and needed a way to get the racecar to the track. This seemed like the coolest way to do that. It came on stock 16's all the way around and I threw on the 22s and big brakes. I think I might need to go with a slightly lower profile tire because there are a few clearance issues... I don't see a lot of info on slammed one tons like this?
The Malibu isn't the endurance racer. That's a car I just picked up to tinker on.
Anyway, Hello everyone!
fofiddyfo
wisco
R3500
Welcome from Wisco, and cool rig!
That's badass! Welcome! Lots of guys down south run setups like that, 6/8 on 22s on a dually is fairly common. You definitely need a lower profile tire though
iansane
Tacoma, wa
Ian
c30
Thanks!
The problem I ran into is the weight capacity dropped SIGNIFICANTLY just going from the 275/50 to a 275/45. Maybe I should just chance it.
Thanks!
I'm not well versed in it since I don't have one and haven't done the research but I know I see guys towing HEAVY on 22s and low pros alot. Maybe there's other brands or other sizes that are still heavy rated?
Edelbrock
Earth
Grumba
K5 Blazer
Your tires look fine to me.
Perhaps that front fender could use a little paint above the wheel well.
Maybe something like this:
Strick
Dunn, NC
Harold
C20 Crew
Welcome from the Tarheel State. That’s an awesome ramp/wedge that you have there!
HS
jbwhitford
