Edelbrock
- Mar 28, 2025
- Earth
- Grumba
- K5 Blazer
All of the sudden the rig can't accelerate. Heavy heavy miss and stumble about 1200 to 1500 RPM. Lurching and popping if I floor it or even try to accelerate normally. Have to baby it. Also, when the engine cuts out and stumbles, the tach needle drops, like the power supply is cutting out. Needle drops way faster than RPM and then bounces back up and registers properly then drops again. This is not fuel related. It's a short in the distributor or something. Should I just run a jumper from the battery to the distributor and unplug the tach, just to get home? Just baby it home as is?
