While the Engines out on a stand
garzas23
Brazoria County TX
AJ
My 350 is out on an engine stand and I was wondering if it could be bad for anything internally or fluids to flip it over upside down to replace the oil pan gasket? The intake, pulleys, water pump, timing, cover, is all off, but the heads are still on.
Also, I finally plan to put it all back together by sunday an fire it up so any tips would be appreciated for anything I should do before its back in and I go for the first crank in awhile.
Should I worry about flushing the coolant in the block while its on the stand, or priming the oil pump. Its been out for about 2 months being painted an a few upgrades. (Pics will follow soon)
Thanks..
MadOgre
NA
NA
NA
NA
NA
Remove the oil pan while the engine is in the upright position otherwise all the crud and shavings are gonna drop onto your rotating assembly VERY BAD!!!
After the oil pan is removed you can rotate the engine upside down to reinstall your cleaned oil pan.
garzas23
Brazoria County TX
AJ
Ok great.. Already drained all the oil and cleaned the pan real good.. Thanks
Have rags or something handy, coolant will probably come spilling out when you rotate the motor.
garzas23
Brazoria County TX
AJ
What about priming the oil pump before i start it? Its been out a about 2-3 months. Will that hurt anything?
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Leave the coil unhook and plugs out and crank it for about 30 seconds to a minute. If you have an oil pressure gauge you should see pressure register but I would crank it some more to be sure everything is pumped up. That is unless you have the priming tool or a modified old distributor to prime it with. Then you leave a valve cover off and just verify you have oil at the rockers.
MrMarty51
Eastern Montana
Martin
Install new valve stem seals too, while they are real handy like.
A six foot piece of 1/8th" nylon rope, bring a cylinder onto the bottom of the intake stroke, shove the nylon rope into the cylinder, crank it over by hand until there is resistance. Remove the valve spring retainers, replace the seal, put the retainers back on, move to the next cylinder in the firing order.
New rear main cranking shaft seal too.
Driver4r
Nebraska
Trevor
k10,c20
pressurizing the cylender does the same thing haha
MrMarty51
Eastern Montana
Martin
Ever have a valve pop open on You, while the cylinder is pressurized. HA :emotions33: :happy175:
Almost impossible to keep the piston on top, always wants to blow to the bottom of the hole.
A friend was using air, popped the keepers loose, for some reason the valve popped open, ooooops. :popcorn:
Driver4r
Nebraska
Trevor
k10,c20
nope, and i changed all 16 in my 355. but the heads were fresh, so i guess they probly sealed better then non fresh
MadOgre
NA
NA
NA
NA
NA
The engine stand is the perfect time to make it all nice and shiny! New paint:)
MrMarty51
Eastern Montana
Martin
A lot of people do`nt have a compressor so, I always throw out the O~L rope trick. LOL
I have a good compressor but, it seems that the rope in the hole works quite well. "Always remove the neg. battery cable though."
garzas23
Brazoria County TX
AJ
Got it kinda shiny now.. Painted it gloss black and installed most of the bolt ons.. Hopefully will be dropping it in next weekend.. I'll have a better post an more pics soon with the details.. Thanks everyone!
Skweegle89
Oklahoma
That looks awesome.
firebane
Calgary, AB
Curtis
Don't use the battery and starter to prime the motor. Pickup a cheap priming tool for a drill and use that method instead.
bigcreek
