Where'd My Fluid Go?
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
One compartment of the master cylinder is empty. No leaks on the ground so where could it have gone?
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
Any number of places, that's the rear reservoir, so maybe it's going out the wheel cylinders or something.
Fill it back up and get someone to work the brakes while you look for leaks.
kdo58
Puyallup wa.
k5
Probably in your brake booster. Do you hear a whooshing sound when you apply the brakes.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Yes, a very loud whoosh.
kdo58
Puyallup wa.
k5
Your brake booster needs replaced and your master cylinder
Yep, that mystery is solved. Brake Booster sucked the fluid out of the master. The fluid is in the booster.
aaron06
