74 Shortbed
- Aug 12, 2013
Looks good..
4.10's and 31-33in tires are a great combo for that sweet spot with an OD Transmission. You're getting the better of both worlds. 35-37in tires with a 4.56 ratio, and 28-30in tires with a 3.42-3.73 are usually good combos.
so a 86 k10 with a stock 2006 5.3/4l60E out of a crew cab with 31" tires.....3.73 or 4.10? I'm looking ahead. LOL I think either will be a lot better here in Kentucky compared to 3.08 that I have now. Want to get the max gas mileage I can.
Thanks for your input HR
Thought I'd share this.
I added 2 extra courtesy lights. I was able to splice into the original single floor light that's in the middle, and added additional lights on each side. Power is orange, then a ground (white) from each side to trigger the door ajar light to ground (left and right side door(s) have their own ground), and a third ground wire from the headlight switch to trigger interior lights when turned on by hand. I just grabbed two extra middle lights from the junkyard, adds quite a bit of light, and looks factory, mounted under dash like factory one is:
installed blue suburban bucket seats and center console in my dually crewcab. will post pics later on
here are the seats
Is it bad in your neighborhood?
no but you hv to protect your investment
