I know a guy who got into a truck at about just after dusk one night to find a snake crawled across his foot. You can bet, he added a light under the dash. 2 like you did would be even better. I thought about putting them in the kick panels on each side.
HEAVYCHEVY82
tennessee
keith
i got my 82 c10 4 months ago don't have a garage so it's gravel driveway under blue skies in tn.so far ive degreased the motor,cleaned carb new intake,new gaskets chrome valve covers,new radiator,painted it and some other odds and ends.this truck sat over a year and is all original lol and i mean all.i can't believe the power windows and locks still work and the clock when it wants too.oh also installed an electric fan.it's been well over 100 here with humidity and she aint got over 200 dgrees yet.even in town driving.looking forward to fixing her up when my wallet lets me.right now just enjoying the cruise and learning.any tips would be appreciated.
Camar068
10 yrs Air Force
4.10's and 31-33in tires are a great combo for that sweet spot with an OD Transmission. You're getting the better of both worlds. 35-37in tires with a 4.56 ratio, and 28-30in tires with a 3.42-3.73 are usually good combos.
so a 86 k10 with a stock 2006 5.3/4l60E out of a crew cab with 31" tires.....3.73 or 4.10? I'm looking ahead. LOL I think either will be a lot better here in Kentucky compared to 3.08 that I have now. Want to get the max gas mileage I can.
Thanks for your input HR
If it were 2wd, the 3.73's would probably do good too, but being a 4L60-E, I want all the strain off that transmission I could get and with 4.10's. Being that's really a 4x4, I'd go 4.10's cuz you might change your mind and want to go to 33's in the future too. If even think you might consider 35's someday, I'd go with 4.56's. JMO.
CRM
Pasco, Washington
Casey
K2500
350 CI
Installed a new ported vacuum switch I ordered from RockAuto. Next up is a new bezel which should be here this weekend.
Camar068-- My truck doesn't have a headliner or interior trim which would allow me to install a dome light. I've thought about adding some but I actually kinda like the old fashioned under dash light. I must admit I liked the earlier post with the additional lights underneath though.
Jarhead79
Mt Vernon il
Michael
Needed some cheap gauges because my water and oil gauges in the dash dont work and the gauges that were hooked up in it were broken and falling apart. So I picked up these Eqqus gauges and installed them!
r67northern
Louisiana
Leland
Suburban r20
Thought I'd share this.
I added 2 extra courtesy lights. I was able to splice into the original single floor light that's in the middle, and added additional lights on each side. Power is orange, then a ground (white) from each side to trigger the door ajar light to ground (left and right side door(s) have their own ground), and a third ground wire from the headlight switch to trigger interior lights when turned on by hand. I just grabbed two extra middle lights from the junkyard, adds quite a bit of light, and looks factory, mounted under dash like factory one is:
That's looking nice
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Looks good! Did you mount them up against the kick panels?
Sent from my SM-G935P using Tapatalk
anubisani
MIAMI, FLORIDA
SEAN
R/V 3500
454 TBI TH400 4:11 gears
installed blue suburban bucket seats and center console in my dually crewcab. will post pics later on
here are the seats
silverscottsk10
trafalgar indiana
mike
here are the seats
Is it bad in your neighborhood?
tweeter68
