Georgeb
Wisconsin
George
K10 Burb Z71
Don't worry @Old77 that may be coming from the guy getting the sloppy seconds after your done.:shrug:
@animal DOES like it sloppy. That is for darn tootin!
animal
Lee
c10 silverado
350ish
I am sure that it would NOT be sloppy after I got past the part you had been using.:whymewhyme: Just sayin :Wave: I wuv u Cob :kiss:
You disgust me to the core :whymewhyme:
:wave:
CRM
Pasco, Washington
Casey
K2500
350 CI
Installed a new temperature control assembly.
r67northern
Louisiana
Leland
Suburban r20
Been working a few things over: trailer wiring is coming along for some RV towing. Found a leaking steering gear, so replaced that this weekend and the pump too. Over the last couple week the R20 got new injectors that really helped clear up some stumbling too. I've got to learn to work on this beast when it's cool outside though. Louisiana is hot right now!
animal
Lee
c10 silverado
350ish
Bought it and cleaned it up. Replaced the wipers, Re-attached the rearview mirror, cleaned the carpet, and polished the bands and centers.
NOPHO84K30
north phoenix
justin
1984 silverado k30
K30 dana 60 corp14 ff
454 sm465 np205
Started this today cam swap. Chain was sloppy cam had a wiped lobe and distributer mechanism was locked up. No wonder it ran like dog doo. Finishing up tomorrow hope it takes new cam well. Ill post a cam pic tomorrow its bad.
Thems ain't no peanut port heads !!! You going OEM cam spec? I think I'd at least go RV or step or 2 over. Though no telling how tired the bottom end is. Oil pressure good? :shrug:
NOPHO84K30
north phoenix
justin
1984 silverado k30
454 sm465 np205
Ya i put a performer plus rv in it. with new lifters New chain comp cams roller tip rockers push rods edel water pump. At idle it has about 30 oil psi running down road about 45 50 psi. The heads say 236
NOPHO84K30
north phoenix
justin
1984 silverado k30
454 sm465 np205
Heres the cam
NOPHO84K30
north phoenix
justin
1984 silverado k30
454 sm465 np205
Got it up and running. its like a new truck so much better more power, runs smooth no valve train noise.
74 Shortbed
Glad to hear you got it running good..
csward86
