Driver4r
Nebraska
Trevor
k10,c20
Try telling that to the people who bring in batteries insisting it's the only possible problem, they usually state that there car is a "make" and is only "x" years old (usually 5 or more) and has never had any starter or alternator or even wiring issues and because it's a "make" everything is perfect and it must be the battery. Yet they'll continue to buy our batteries for all there other cars. I actually had one guy tell me that it must be the brand new battery because his 1964 ford had no issues when he parked it 10 years ago. Why did it get parked? Did you flush all the fluids out and put fresh fluids in? did you replace the rubber seals and lines? did you check the cables for corrosion? is the starter rusted out? does it have gas? "It's a ford, nothings wrong with it except this cheap battery!" ok here's a new one, see you tomorrow.
Well, OF COARSE it wont start..... ITS A FORD.
Getting her licensed as an antique vehicle this friday :party33:
Chadwick
oakboro, nc
Chadwick
1/2 ton
Got it back last Friday....
Is that the GM Sunburst Orange color. Like used on the 2002 Avalanche's?
El Camino Man
SO IL
JP
R30 Scottsdale
6.2L
Why would someone paint an Avalanche? Arnt they always white :anitoof:
HAZZARDJOHN
Medevial England Iowa
V1500
I figured out why my new serpentine belt was squealing. I missed the idler pully! :slap: Almost twenty years of putting belts on cars and I have never missed a pully. How they hell I have been driving for four days with it like that.
IIRC, that actual color name is Sunburst Orange Metallic. I never did like it on Avalanches, but I've seen a few other trucks that are painted that color and they made it look good.
travisr1988
Cedar Park, Texas
Travis
C20 Silverado
Well, yesterday me and the girl got a new car that's suitable for a baby since she's pregnant, a 2010 HHR, nice car, good mileage, no balls, she loves it, so I'm happy. Today I removed the whole front clip, dash pad, and pulled out the motor and tranny so I can tear it down and see what happened and whether we can rebuild this motor for only a little more than the 2 bolt main that we were going to use. Of course as soon as we separated the motor and tranny and got the motor on a stand and ready for disassembly it started raining so that'll have to be disassembled Monday or Tuesday as I work all weekend as usual. Turns out in addition to replacing the fender with one the p.o. gave me when I bought the truck I may also need to replace the radiator support as I had to cut one bolt out of it to get the fender off (heavy corrosion/rot due to battery acid, just below the rotted out battery tray). Of course I already knew I needed a battery tray and inner fender as well, other than that things went rather smooth. I also discovered a body ground that was not properly mounted (wire wrapped around bolt under head, should have had ring terminal crimped on...$.05, 30 seconds of time). And I also found after moving the a/c compressor that my coolant temp sensor wire had been exposed and bare wire was touching the valve cover...that explains a couple things. Cylinders #3 and #4, or maybe it was #5 and #6 had a little bit of moisture in the exhaust ports when we pulled the exhaust manifolds (bolts came out like butter on all). I'll update when I get the motor apart and take pics.
hmmm, had me believing you tore down the girls NEW HHR that she loves so much.
El Camino Man
SO IL
JP
R30 Scottsdale
6.2L
That's what I thought for the first couple sentences and thought WTF?!
Good car, great mileage, slow as hell, so we tore the motor down lol
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Installed the new starter. That sucker cranks so fast, it's like nothing is attached to it! Love it. Fires right up.
Snips71
