under powered
82withproblems
Bend, Oregon
Jody
k5 Jimmy
I just bought an 82 jimmy with a 350 and 2 barrel carb. It is extremely under powered and I don't even know where to begin fixing it. My plan is to fix up the running gear and then focus on the body and the interior. The engine starts alright but it seems very sluggish. Anybody know where a good place to start would be? I'm also having problems with my automatic transmission. It doesn't really like to go when it's in reverse.
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
Aluminum intake and a 4 bbl carb, I prefer quadrajet carbs they're one of the best running carbs out there, and a simple edelbrocker performer aluminum intake would help a lot, and a set of headers would help out also with maybe exhaust. That's what I would do, get it breathing good, but at the least an intake and carb would be a good start.
CSFJ
Not so sure any of that will work without a new cam to make use of the new breathing ability. Used to see that a lot back in the 80's. Someone would get some old v8 car from the 70's throw on a four barrel carb and intake, and ignore the factory cam that had a profile designed to work best with a 2 barrel carb. Then they'd complain how it ran worse than before.
marks86
Latham, NY
Mark
12v Cummins
im assuming you've done a basic tune up? plugs,cap,rotor,coil,wires,etc
firebane
Calgary, AB
Curtis
What gears you have in the back. You can do all the upgrades you want but gearing will make a big impact
350runner
tx
Ceasar
an rv cam will low duration and approx .44 lift will do just fine. it'll boost that low end and take advantage of any bolt ons you add. plus your mpgs won't go out the window.
bigcountryguy19
Sealy texas
josh
6.2 diesel
Is it smoking or anything? Maybe the engine is just tired and needs a rebuild?
77 K20
Montana
K20 5" lift
HT383 fuel injected
Have you done a compression test on it yet?
beest
indiana
matt
Headers and dual exhaust will give ya a nice bump in performance and mpg. If you can get away with it where you live, getting rid of the catalytic converter will help also.
MadOgre
NA
NA
NA
NA
NA
The 4 bbl aluminum intake will help a lot regardless of whether its the stock cam or not.
You need a good 4 bbl carb and a matching intake before you can swap in a cam anyways!
I would put headers on and dual exhaust with free flow mufflers and then accumulate all the parts for a 4 bbl carb and intake (aluminum ones are best with no EGR) And then finally purchase your cam.
Edelbrock 2101 with a good Quadjet
Edelbrock 2701 with a 1406,1806,1826 Edelbrock carb
Use Felpro 1256 intake gaskets for either manifold.
If using anything other than a Quadjet you will need additional accessories that you cant find at the local junk yard like throttle cable brackets and fuel lines and what not. it cost me almost another $200 just in little **** to get my Edelbrock 2701 and 1806 carb working.
Although Quadjets are superior carburetors to Edelbrocks carter style carbs, they do leak from the fuel well plugs where as Edelbrocks do not. You need to find a pro to fix this properly unless you are quite knowledgeable and able to do it your self.
Put the exhaust on first then do your cam swap with the 4bbl carb and intake at the same time.
Or do the cam later.
But you need the 4 bbl carb and intake regardless!
mjek421
