dvdswan
- Mar 11, 2014
- Port Orchard, WA
- Dave
- K10
78 K10, 350, 4sp, 205, dual tanks. I'm not getting fuel to carb. drivers tank is full, pass tank 2 gallons. I've had an intermittent stall issue since I bought the truck (its not my daily), didn't matter if it was hot/cold, dry/wet. It would happen only going up a hill just not all the time.
I've replaced both tank sender and clean out the tanks about a year ago, they were dirty, socks were brittle and really none existent and had junk in the tanks. replaced the switch valve when I bought the truck as it was bad. just replaced the mechanical fuel pump because there was no gas to the carb and replaced the fuel line to the carb as it was kinked and installed fuel hose with extra fuel filter. the carb has been rebuilt about 2 years ago and help performance and gas mileage.
I'm still not getting gas to the carb from either tank. now I'm stumped.
any suggestions?
any suggestions?
