dkraven
- Nov 15, 2022
- Portland, OR
- David
- c25 Sierra Grande
Neighbor moved and gave me his 77 Sierra Grande last fall, told me engine runs great but thinks sediment from the fuel tank (truck sat a lonnng time) is clogging the fuel line because it only starts if you pull the fuel line off the pump and blow compressed air through it. Sure enough there's no fuel coming out of the hose and after he blows air into it fuel comes pouring out. He hooks it up to the pump and the truck started right up.
The truck stalled twice going around the block to my house and we did the air thing twice more because each time the fuel hose to the pump dried up. I decided to replace the fuel tank and sending unit since he thought sediment from the old tank was the problem. Few months went by as I waited for it to warm up, replaced the tank, learned a lot about cramped space work, put a few gallons of fuel in the tank, sprayed starter fluid in the carb ... and aside from firing twice from the starter fluid nothing happened.
Decided the mechanical fuel pump would be pretty cheap to replace and might be the culprit. Went ahead and replaced it. Sprayed starter fluid in the carb and the truck fired up! Decided I was a genius, drove the truck around the block, sounded pretty clean. There was some smoke from the left header but figured I could diagnose that later.
Two days later it wouldn't fire up. Pulled the fuel hose off the pump and it was dry, no fuel coming out. Tried my neighbor's air compressor trick again and fuel flowed from the hose and the truck started. Over the next two days I started it fine each day without blowing air, and then yesterday once again it wouldn't start.
I'm not sure where to diagnose at this point, or why blowing air with the compressor into the hose prompts fuel to start flowing again. Once started up the truck will drive without stalling, so fuel keeps flowing once it's running. My next idea is to disconnect the tank switch unit under the truck as it has dual tanks and maybe there's a bottleneck in there? The right side tank is still the original and I'm just not using it until I can get one tank working. I had one person suggest it has something to do with the carb, but I don't see why that would be since the problem appears to be on the other side of the fuel pump from the carb.
Want to do right by this truck, so anyone with experience or understanding of the mechanics of what's going on here, I'd sure appreciate some help. My knowledge only goes as far as what I've learned struggling with this truck and reading on the internet. Thanks!
