Steering Box Question - 2wd to 4wd conversion r3500 Crew Cab
Skyfall
Franklin, VA
Ryan
r3500 Crew Cab 4WD
350ci
Hello all...
I read this thread about the steering boxes (https://www.gmsquarebody.com/threads/squarebody-steering-box-id-and-interchange.3991/) and I noticed how similar the 2wd and 4wd steering boxes are.
My question is:
If I purchase a dropped pitman arm from someone like ORD and place it at the correct angle, can I use it after I swap in a straight axle into my 1991 r3500 in a push/pull steering configuration? I want to install a GM sway bar which is why I'd opt for the bump-steer prone push/pull steering.
I've spent hours researching the Crew Cab 2wd to 4wd swap and can't seem to find an answer to this one.
Regards,
The two boxes use a different sector shaft.
What axle are you installing? What springs are you going to use? What are you going to use the truck for?
Bennyt
Surprise
Ben
Will it bolt-on? It should but if I recall, arent the tie rod mounting pad angles different which might cause a bind?
What size tires are you planning on running? On my K5, I bought the parts to do crossover steering but never did as I wanted to retain the sway bar. I figured the benefit of a sway bar on a 90% street driven outweighed the bump steer. I never felt the bump steer was that bad and I ran 33's, 35's and 37's.
The best would be to do crossover and build a new sway bar. Probably cost $500 or so in parts plus fabrication. I'd contact swayaway and/ or ORD.
I'd also look at the ck5.com website.
The reason I was curious about specifics was because crossover steering is simple and cheap with a 2wd box and a D60. And even for 100% street use, the sway bar is completely not needed, unless the springs are very soft and/or the rig is top heavy for whatever reason.
I've said it a bunch here over the years and I'll say it again too, lol. Most anyone that says they need the sway bar for street/highway use, has not actually ran without one to see how it is.
Skyfall
Franklin, VA
Ryan
r3500 Crew Cab 4WD
350ci
Thanks to all of you for engaging in this discussion~!
I am planning on running a Dana 44 or Corporate 10-bolt from a K20 or K30 truck or Suburban. I am still trying to find one.
This truck will be a road queen and not my daily driver. I've previously owned/restored 3 square body trucks, this is my first crew cab and first 2wd.
I am going to install 6" of lift, 15x14 Bart wheels and 35/16/15 Super Swamper Boggers. If it was a daily driver, I wouldn't do this, but it isn't so I am going with the look I want versus comfort. I ran 36" Mickey Thompson MTZs on my last truck (1985 Suburban) and they rode like a car.
If I can use my steering box and an dropped pitman arm, that is what I'd prefer to do, bump-steering issues and all. I can always upgrade in the future.
Bucket, I believe what you are saying about the sway bar 100% --You are right, I've never driven one of these trucks without it. I have driven one without steering stabilizers and experienced the death wobble at 35 MPH...never doing that again.
Regards,
Here are a couple pictures of my '85 Suburban.
That's a familiar combination!
Skyfall
Franklin, VA
Ryan
r3500 Crew Cab 4WD
350ci
Nice Suburban!
I think I have all of the information that I need, but I have one more question. Is $515.00 a good prince for a used Dana 44 front end (with 4.10 gears to match my rear) out of a 1979 K20? That price includes shipping. I have seen prices all over the place. I just want to make sure I am in the ballpark
Thanks...
Nice Suburban!
Thanks...
It used to be a $100 axle. But getting much harder to locate these days since the scrapage rate has been so high. If shipping/delivery is involved, that seems reasonable to me.
Skyfall
Franklin, VA
Ryan
r3500 Crew Cab 4WD
350ci
Thanks again...
Sent from my moto g(7) power using Tapatalk
Craig 85
Nashville, TN
454/TH-400/NP205
I would agree the price seems good for a D44 with shipping. I don't know your budget, but if you do the cross over steering, ORD has a sway bar for that set up now.
Skyfall
Franklin, VA
Ryan
r3500 Crew Cab 4WD
350ci
I placed the order for the axle today today. :)
I will take a look at the sway bar / steering setup from ORD. I may go that direction. Thanks for the information.
Regards,
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
You definitely won't need a sway bar with a crew cab long box truck lol. A blazer or a short box would be the only trucks I would consider a sway bar on, but even then depends on springs and stuff as said above.
Skyfall
Franklin, VA
Ryan
r3500 Crew Cab 4WD
350ci
I've read a lot about the rear spring hangers on a 2wd being lower than a factor 4wd (2", IIRC).
Based on that, my question is:
If I install the all of the front hardware and 6" springs can I effectively level the truck with 5.5" rear blocks? I don't mind a slight lean on a truck that long, but nothing over 0.5" to 1.0".
I've researched this and haven't been able to get it straight. Hopefully, one of you can tell me the answer.
I can't wait to get this project under way.
Regards,
jp wessels
