Spicer spring
MOguy
Missouri
Ross
This blowup is from the 1980's. Has the part number been superseded? It's worth asking.
They said it hasn't been made in years. I called some restoration companies I found on the web and they said they use newer replacement hubs.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
I had a set of Spicers on mine when it had 1/2 ton axles. I'm not sure if I still have them in my junk or if I gave them to [MENTION]Swims[/MENTION] a couple years ago.
MOguy
Missouri
Ross
the half ton would have the dana 44, not sure if the spring would be the same size or not.
crazy4offroad
Curt
K-10
350/SM465/NP205
It was actually a Corporate 10 bolt. If the dimensions are the same it should work.
MOguy
Missouri
Ross
I will have some time this weekend to check things out. I hope they work.
MOguy
Missouri
Ross
The spring was too small but I was able twist spring to increase the diameter and it worked. The ring that holds outer cap is out of round so if doesn't look un lock. I can probably work on the ring a bit more. Next is a new rim and front tires.
So obviously that answers that question. The 1/2 ton Dana 44 / Corp 10 bolt Spicer hubs won't interchange or at least have smaller springs than the Dana 60 hubs right?
I'd still keep your feelers out on the correct spring, even if it came off a Dodge or Ford Dana 60. Never know, someone may have had 1 hub lock go bad and bought a new set of Warns or something else and all you need is 1 spring from their replaced Spicer hubs. Needle in a hay stack but it could happen.
MOguy
Missouri
Ross
Definitely. One on the rings in the hub is out of round so I can't unlock the one side. If I can't get it right with replacement parts I'm will get new hubs. But for now 4 wheel drive works and can get around my proberty. I want to have the truck completely road worthy before my son is driving it on the road.
The good news is, if you do end up buying new hubs, knowing how hard it is to get separate parts, you now know you can probably sell the single parts on eBay and make a few bucks and help out another off-roader looking for the same spring whether it be Chevy, GMC, Dodge or Ford, cuz I'm fairly certain the springs are the same on all brands, but it was Ford that was more common to use the Spicer joints. Not sure what Dodge used.
MOguy
Missouri
Ross
I am hoping to stay with the Spicer. The Warn and Mile Marker hubs aren't supposed to be as strong. Yukon makes a good set up but it is more money and Dyna trac makes a kit including other parts that is supposed to be bullet proof but that cost even more.
I think the difference in strength only matters on a hardcore offroad truck. New hubs can work real nice for a long time on most any work truck.
crazy4offroad
Curt
K-10
350/SM465/NP205
I think mine has Mile Marker hubs and I've beat on them pretty good. The hardest hardcore offroad trucks don't run lock-outs anyway, they run slugs.
MOguy
Missouri
Ross
I can be carrying over 2 tons of fire wood and more than that in gravel or dirt over less then ideal conditions.
k5inAJ
