Rust Attack Part II
I finally got this part in. Passed inspection without it though.
So you got it to pass inspection now? :)
Ok fellas, need help with this, got inspection around the corner. I think as long as I replace the rusted away bolts and clean all the nasty **** out and make some kind of bracket on each side to bolt to the fuggin floor for the body mounts I wont have to worry about replacing the entire section all the way across.
http://www.gmsquarebody.com/forum/showthread.php?p=81055&highlight=mount,+rust#post81055
I can't see much in that pic :confused:
That's because what is supposed to be there, aint. :roflbow: I got to go and move my truck to the office right now anyway, let me get a couple good pics. :)
:sudu:
attachment.php
[/IMG]
Wow....reminds me of the body mounts brackets under my cab when going through my resto. You could probably get some metal and fab up your own replacements
fredflinstone
st. john's
fred
that looks nasty. Deffinetly a self fabrication job for yourself
I know you just want simple and functional. How about cutting out the bad area on each side and just shove a piece of rectangle tubing in there, with a hole for the body bolt?
Eden,NY
Travis
Sierra
That seems like the easiest and cheapest way to me if you ever need to order patch panels I've used www.fixmyrust.com before and was happy with the fitment never had to return anything though. There prices are pretty cheap too
Here's a link right to the 73-91 burb
http://www.fixmyrust.com/index.php?app=ecom&ns=catshow&ref=CG&count=20&offset=0
Yah. I will try something like that. Just got to get this thang past inspection. I will figure something out. I got to pull the rear interior all out again and cut the welded heads of the bolts off the fuggin floor under the third row seat. Phil me I am getting tired of this. One day at a time. Feels like a phucking cracked dam I am sticking fingers and toes and bubble gum into to keep going and stop the inevitable flood of disaster. I love her though. :(
Gord
