R&R Suburban Tailgate Upper Glass Run
BryanC
USA
Bryan
C1500
Hi - I need to R&R the (fiberglass?) tailgate upper glass run that goes between the window and the body on my 1974 Suburban to treat some surface rust between it and the body. Does anyone have directions on how to correctly R&R this piece? Thanks!
BryanC
USA
Bryan
C1500
Here is what I found: Remove the upper glass run felt, remove the screws for the tailgate seal, then you can remove the sheet metal screws holding the three pieces in place.
yevgenievich
Viktor
sad
very sad
less sad
There is supposed to be some seal that should be behind the side pieces. It was missing on my old suburban and I had to use a lot of sealer instead. Otherwise I would get water leaking heavily through that area
Wrenchersllc
