Project Mini me
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Went out to deal with rubbage....
First side that was rubbing came out ****...
The other side not so much... Tried to clean it up from jagged edges, and got a little herky jerky...
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Took her for a maiden voyage to get valve stem caps as someone took mine to autozone. No rubbage at all.
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
I saw these on craigslist and just picked em up.
Barely fit . Had the door ajar light the whole way home... Thought they were 33/11.5/15 but they are 33/12.5/15. Couldn't beat the price.
Gunna see about mounting and clearance issues..lol theres more fender there to make the radius sharper
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Woke up early and brushed/ cleaned the tires...
Also made a "marked up" ad on CL... I may keep em or flip em depending on market. I kinda went up into a more rural area and brought em back to a city area so may do okay on em... Been thinking if I fliped these with swamper spare for say $220 + ats with bfg spare for $220, I might have close to enough for new set of 33s...
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Stock rear fenders with 32s....
33s...
Different angle...32s....
Got some trimming to do of the lower section... Then will mock up fronts...
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Put in a lot more work than I thought it would take, and then had to stop after only one corner was complete, as I have to drop her off at the shop tommorrow for bumper install Thursday, then pick her up maybe Fri... And my whole purpose of going out was to sand and respray my roof rack black to cover up where it is chipping away...
So here was rear fenderwell work...
Kinda cut vertical, then recess cuts, then pushed inner piece in a little, then hammered piece back over itself...
Painted drums while in there as I had Broken the center caps yesterday in preparation for tire wheel swap in a hurry before I found the new tires has sidewall hairline cracks I dont want to risk running... So I posted them back on cl, and am using the one mounted 33" for clearance mock up...
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Painted the inner wheel well rustoleum black... Still gotta seam seal...
Metal removed...
Iowan
Loud and Proud American!
Iowa
Calvin
K1500
350 crate
Wow! Looks great!
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Stock gap on other side ( still got three more)
Gap after...
Funny how you always end up brute strength hammering at the end of the day... Not bodymam perfect but will get her done...
Bumper shortly...
jcuriel512
