Project Mini me
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Ph yeah, it was leaking at the bottom of the pressure hose when I got it... Now I see why they left it.... It felt really tight but was weeping, then strip, and hopefully new will go together better.
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
So I finally got the new pressure hose, and ps pump, with all the brass washers. I will thourpughly clean and inspect banjo bolts at both ends.
Of course I got all this before I go back to work after a few days off, but now just install and hopefully done, brake bleed, and alignment, and she should be ready to drive, and final bumper install, but may need a shop to weld it.
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
I was thinking the reason there is no slack in the pressure hose is the two inch body lift, but not so sure. Hopefully I don't have to get a custom one 2" longer.
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
So happy I used the forums upload platform as photobucket wants $300/ year now....:mad:, so all those pics are in limbo.
My other build looks horrible due to all the missing images but I'll work it out someday... At least this build is still going strong.
So I jave been lagging, but today for the ps pump swapped out, pieces changed over, and laid the pump with upper hose connected in the engine bay with plenty of slack so I can hook up the bottom of the hose to rack....
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Welcome back man good to see this lil guy moving forward again.
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Also got outer tie rods end in...
Got some other goodies waiting for the right time...
Trailg gear rear mini spool, 14" electric fan, and plastic mounting kit.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
And a cat....or was that packing material?
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Good to be back. My ac went out and its been pretty hot... I was able to change 4 capacitors and its running better than ever, but it took time to troubleshoot, and I had to buy a ladder on CL , as the ladder I had was buried behind my square.
:rolleyes:
I also worked 8x 12 hr shifts in 9 days thinking the ac was going to be a $5-10k replace, so lucked out with about $200 in parts and fast shipping.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
:rolleyes:
Well that's cool it was only 200 mine freezes up when it gets super humid. So I give it a rest every so often lol.
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Couldnt keep him away...
Check this out... He wants it the minute I pull it out for the pic..
He looks at me while I give him the " you better not" stare....
and.... He doesnt listen, and cant keep his paws off it... Silly cat..
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Lol my dog would been barking at it.
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Had to slide down the side of my truck and crawl under its belly to reach for some vice grips to get a stripped nut...
Got the fan out...
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Another angle
Had some concern with running the electric fan with this ac fan right in front of it
Still gotta attach ps hose and put her back together but engine was dirty so wanted to carb clean first..
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
As long at they don't fight each other and just think you can get first hand view of how a torque converter works if you fire up the ac fan and the inside fan starts to turn with out power. Lol
strokedK15
