Powder coat frame
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
And again guys, rust converter after sand blasting... rub it in good with a soaked rag. Then wash off with water. Then prime and paint. If rust returns (it will) you can see it bubbling the paint and it's easy to get to it and fix. Any kind of undercoat or rubberized bed liner stuff will hide the eventual rust that will return and until it gets really bad you won't see it.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Did you use rust converter first? Your frame is probably rusting underneath the undercoat. Sad thing is you won't see returning it until it gets quite bad.
I always do that when I use it now. Back then I did not, I’m afraid.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
my phosphoric acid solution says to leave it on overnight then to wash it off with water. water on bare metal just before you prime it sounds kinda funny, but they are the chemists, not me.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
I think it’s to stop the reaction because it’ll keep going and turn all white and gross if you leave the acid there.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Same as converter, you have to wash it off with water before you prime. At least the raw metal is left in a state of... oxide prime!
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
Water neutralizes acid. If you left it sitting there, it would be a problem, but if you wipe it off, no harm done.
Tazdar
