please help! C10 Lower Control Arms
yevgenievich
Viktor
sad
very sad
less sad
I will have to verify after it stops raining, but the looked to be ok.
bob3975
US
bob
Orielly auto parts sells them 65 each is what I paid for mine
Sent from my LGMS330 using Tapatalk
dphipps
Canada
d
I just disassembled a set that were seized on, took me roughly 2 hours and I was done both arms. I used a cheap air hammer and a bit of swearing. It really wasn't that bad.
I pressed them back in with a 'press' I made with a bottle jack and some scrap tubing. I have a couple pictures if you're interested in going the DIY route.
There you go, Case and Point !!! :waytogo:
gazooba
Calgary, AB
Greg
Heavy Half
Since this question is here, my C10 lower control arms are also toast. I think my brother in law crashed into something as the tabs on the arms where the shafts go are badly bent. In my case, I really do think that I need new arms. Everything is rusted and buggered on mine.
So, to my point:
What actually are the differences between C10 and C20 lower control arms:
Can we buy C20 arms and press in C10 ball joints so that the C10 spindles can be used?
Does the C10 spring fit in the C20 arm?
Sway bar / shock mount locations are the same or not?
Thanks!:cheers:
NO, C10/1500 Lower Control Arms will NOT interchange with C20/2500 LCAs. C20 will interchange with C30/3500's but not C10's.
Obullard74
