O-ring for yoke
74 Shortbed
spanky55amg
I'll give u $5, a hardy handshake, & 5 fish sticks
Dallas, TX
Spanky
C10 Short Fleet
V8
Or... instead of a wine cork table, you could make a cork gasket table... We make a block table and then make a table top using clear resin and cork gaskets.
I dont think our house decorating show is going to make it on HGTV. :)
spanky55amg
Dallas, TX
Spanky
C10 Short Fleet
V8
It only took one day this time. The yoke is leaking... Is there something I should know about the slip yoke or is it all the same size? And Im guessing it needs to be pressed from the driveshaft, correct?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Did you seal that hole up at the end of the slip yoke? Post a pic of the leak
74 Shortbed
As I mentioned before, if you have one spline missing on the shaft you don't need the o-ring and you can plug that hole, the missing spline acts as a vent, no missing spline then you need the hole and the o-ring deal.
spanky55amg
Dallas, TX
Spanky
C10 Short Fleet
V8
I did not seal up the hole. I tried without it. Funny thing is that it only leaks on days above 90 degrees. Its cooled down to highs in the mid 70s and lows in the 40s and stopped leaking.
silicon or epoxy?
And I guess Im out $10, 10 fish sticks, and 2 hand shakes....
74 Shortbed
silicon or epoxy?
Less heat less pressure, JB Weld works good..
74propu
florida
austin
c10s/b c10 s/b c10l/b
5.3 / ?/454 tbi
I just weld the hole closed and put it back on the drive shaft
74 Shortbed
That works too..
Ls85c10man
