NP208 front output yoke seal washer for nut
Chuckd84
Sedley Va
Chuck
Silverado K20
Chasing some oil leaks after letting the truck sit for a few years. My 84 k20 has the 208 t case and im replacing the front output shaft seal.
Ive got the yoke sleeve and seal but wasnt aware of the odd spline shaped rubber seal for the shaft splines. Does anyone know the current part number for this rubber seal washer? Im trying to avoid rtv/reusing the original of possible.
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
I believe I used torque king 4x4, for both the new Yoke and seal. Just make sure you get the right spline count and you should be fine.
PrairieDrifter
North Dakota
Mason
When I did this, Chevy stuff wasn't available, although its new process technically not chevy. So get the right spline and dimensions and you're all good.
The yoke was sold for a "dodge", I can't remember the difference. I think this yoke is slightly taller, but same bolt and hub pattern. I've been running both the seal and yoke for about 5 years now I think. 25,000 miles, doing great still.
Also it was torque king.
Chuckd84
Sedley Va
Chuck
Silverado K20
Thanks for the good info. Im hoping there is a chance my local parts stores might have that washer on hand. I got lucky that napa had the shaft seal and sleeve in stock so maybe ill get lucky again. If not, atleast ive got a known source online.
johnalen76
