No start, no click, no nothing
Gray87GMC
Kansas
Austin
Here you go.
So the only one of these I haven’t checked yet is the braided one between the head and the firewall. I need to check that
Gray87GMC
Kansas
Austin
So it’s not a ground...
And it’s not the ignition switch because I just replaced that...
What the heck truck!
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
An 87' won't actually have a neutral safety switch. It still has the same looking switch body at the bottom of the column, but it's only for the ECM to know P/N and the reverse lights, no ignition wires. Not sure when they made the change, but I think it was around 84-85'. There are physical stops in the column that prevent you from turning the key unless it's in park or neutral.
Interesting....so when I purchased a neutral safety switch two weeks ago and installed it and the starter probelm was fixed......how would my 1987 silverado NOT have a neutral safety switch? Either way, the replacement part was referred to as a neutral safety switch on the parts listing. Call it whatever you want, but it is worth it for the o.p. to check and replace the part.
smoothandlow84
Steve
Neutral safety switch...or whatever you want to refer to it as...it fixed my problem.
Gray87GMC
Kansas
Austin
Ok I’ll look into it further. Someone said that the 87 doesn’t have them. I’ll verify and give it a shot
smoothandlow84
Steve
Well mine certainly does.....or something that specs out as one at the minimum.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Jump the none back up wires together and see if it starts if it does the switch is bad done deal
Gray87GMC
Kansas
Austin
Can you elaborate? I already replaced the switch but they were out of Ac Delco and I don’t trust the part 100%
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
I'd be curious to see a picture of the switch at the base of your column. Both my 87' and 88' lack any starter related wiring running to it, as you can see in the pictures I attached. Should be two purple wires if it really does have a neutral safety switch for the starter, not just the P/N indicator for the PCM, and reverse lights.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Op is your truck still TBI? If so that plastic switch will tell your ECM to not run if it’s bad by bridging the wires it will bypass said switch and the ECM will be given a park or neutral signal to run.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
You sure? The crank circuit doesn't go through the PCM at all, so not sure how the PCM would tell it not to start. There is an offshoot from the crank circuit that tells the PCM it's cranking, but that's it.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Something has to tell it not to start/crank if it’s not in park or neutral. My 87 is stripped of all TBI crap and it starts in any gear so I’m inclined to think your right so I will shut up now. Those green wires have to do something whether it’s fueling or something.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
The green and blue are reverse lights, black/white and orange are the P/N signal for the PCM (for idle control, I think). I tested my column just now, and it won't let me turn the key to the start position when in R, D, 2, or 1. I think the only reason it lets me start it in OD is because I'm using a Lokar linkage for my swap that probably doesn't line up the detents just right in the column.
I'm honestly not sure why GM decided to skip the actual NSS and put it in the column. Seems odd to me. I guess it could be more reliable without a switch to go out of adjustment? Shoot, maybe they even did one or the other depending on certain options? Who knows.
You said yours will crank in any gear; do you know if the column has ever been swapped?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Gotchya, I wasn’t trying to argue and it’s been a while since I hooked up my reverse lights up to my shifter. Also my column is locked in the park position all the time duh on my part.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Op I was wrong and I’m not afraid to admit it. Best I can do is this hey @1987 GMC Jimmy or @chengny help this guy out if you would be as so kind.
MenDeeZee
