chengny
- Feb 22, 2012
- NH
- Jerry
- K3500
If you have cordless power tools with seemingly dead batteries and the cost of replacement batteries is almost as much as new tools, you might want to take a moment to read the following. I wrote it a couple of years ago and have been meaning to post it. It works:
Are your cordless tool batteries not holding a charge, or are they just not taking a charge?
What I mean is;
1. When you put them in the charger, do they immediately show as fully charged (or defective)?
2. Or does the charging light stay lit for the normal amount of time (as compared to when they were new)? When the charger shows them to be fully charged you plug them in and they work- but when you use them they only last a minute or so?
If the problem is number 2; charge cycle is normal, the batteries initially work but have ony minimal capacity - skip this, they are dead.
But, on the other hand, if they only appear unable to accept a charge (as indicated by the red/green lights on the charger pack) try the trick below.
I run Dewalt and Ryobi 18 volt cordless tools (and use them a lot) and have not had to buy a new battery for at least 6 years.
Frequently, after a couple of years of use, the battery charger light will indicate that the batteries are either faulty (or show fully charged as soon as the go in the bay - depending on the make). The owners manual will state that the batteries have reached the end of their useful life and need to be replaced.
But I use the method below to keep charging them. They keep right on working and have no apparent reduction in power or service time.
Take a minute to read this - and never buy another rechargeable battery again:
If it is not already unplugged, unplug the charger from the 120 VAC source - and have no battery in the charging bay.
Then, with the charger still unplugged, snap a battery into the bay.
Get ready to plug the cord into the outlet.
Here is the trick - don't just stick it in and leave it there. If you do, it will show bad battery as usual.
Rapidly and repeatedly touch the blades of the plug into the contacts of the outlet (maybe even reverse the plug a couple of times if it is not polarized).
While you do this, watch the state of charge indicator lights. After a few (maybe 20) of these momentary connections you should eventually see the normal charge light illuminate. It may go out quickly at first but keep making that rapid connect/disconnection. Eventually the lights will stick in the charging position and stay there until the battery is recharged to normal capacity.
It has been years since I discovered this trick, but if I recall correctly, it gets easier with time.
At first it seems reluctant to start charging and takes a lot of "jabs" of the plug to get it to accept electron flow from the charger. But after awhile (maybe just because I got better at it) I can start the charging process in less than 5 attempts.
This is not common knowledge and I am sure the tool manufacturers and the battery companies like it that way.
What I mean is;
