New but love the data shared here...
tony wallace
mendenhall ms
tony
k10 stepside
350 bored .40 over
let me go check, that dang thing might be broken off
tony wallace
mendenhall ms
tony
k10 stepside
350 bored .40 over
no the pin is correct. it is all the way out as you can see from the top of the pinion pin i can stick a nail all the way thru the hole. nothing in there. its the other side any way
tony wallace
mendenhall ms
tony
k10 stepside
350 bored .40 over
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
here it is
They usually slide out sometimes with a little coaxing but I take them out hole end first. Usually the carrier has self clearanced itself against the hardened cross pin making it easier to remove.try to work it back threw the other way if you can.
tony wallace
mendenhall ms
tony
k10 stepside
350 bored .40 over
so once i get some advice on how to get that MF out of there, then i need to buy a new pinion shaft. so can anyone tell me what rear end this is so i order the right shaft?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
By the looks of that retainer that pin was moving and should have come out relatively easily.
tony wallace
mendenhall ms
tony
k10 stepside
350 bored .40 over
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Pinion shaft? Do you mean the cross shaft or did you chip the pinion?
tony wallace
mendenhall ms
tony
k10 stepside
350 bored .40 over
there is no way to move it. i had to slam a huge hammer to move it a centimeter. i have put vice grips on it tight and tried to hammer them to make it move. wont budge.
tony wallace
mendenhall ms
tony
k10 stepside
350 bored .40 over
not sure names. hahaha the shaft i am trying to get out. need to order another one because this one is jacked up. has to be if it wont budge maybe bent a little?
tony wallace
mendenhall ms
tony
k10 stepside
350 bored .40 over
at this point, how do i get the entire center stuff out to where i can take it to my vice and work on getting it out?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Do you have a torch or a butane torch? Sounds like the carrier is trashed that pin should all but fall out. If you do put a little heat on the carrier around the pin and see if she loosens up.your gonna have to bring it out the other way.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
You gotta get the pin out to release the c-clips and pull the axles to get the carrier out.
Ls85c10man
