ok guys, major problem need some help please. i removed the small bolt holding the pin between the axles and the steel shaft that keeps both axles from coming inward is stuck. videos i watched the just slid right out. i had to hammer it hard to get it to move. it was a little space between both axle ends it wasnt hanging there. it was hanging when trying to come thru that gear. i hammered it out enough to spin it around and try to pull out with vice grips. wouldnt pull out. now i have it hammered thru so far it wont turn around to be able to grab and try to pull on out. no idea what to do now or how to get it out. it has marks on it like when that wheel bearing went out maybe that axle shaft was moving around and scared it? not sure. i finally said screw it, i will take a saw saw to it and get it out and just buy a new shaft. that saw saw wouldnt begin to cut it. now i am lost...........
