looking for a small lift for a 1978 K20
ThSlug
Maryland
Matthew
I currently have a 1978 K20 with a 4 inch lift, blocks in back. The blocks are rusting and the bushings are shot. The whole thing rides really rough and it's just a tad too tall for me.
So, I'm looking for new springs. I primarily run to the hardware store, but also haul a trailer and a lot of firewood. I also do a little off-roading from time to time. I'm hoping the new springs will:
1) Give a softer ride
2) Give a lower ride, closer to stock height, but a little lift is ok
3) Keep a positive arch (not the negative arch in the stock front springs)
4) Accommodate up to 33" tires (currently on the truck)
5) Keep my 3/4 ton capacity
So, I've turned my attention to the Tuff Country 2" 3/4 ton all spring kit. However, as far as I can tell, the kit uses 1/2 ton rear springs. Does anyone have thoughts on this kit? How is the ride? Have you towed with it? Does the rear hold up?
Thanks in advance.
77 K20
Montana
K20 5" lift
HT383 fuel injected
I can kinda answer... I bought the Tuff Country 2" HD front springs. They raised the truck 3.5" for me. I called and talked to them about it and they said it lifted it that much because 1) my stock springs were worn out and 2) the HD springs lift height was for if you have a big block engine, a diesel engine, or something like a heavy winch bumper.
For the rear of the truck I put in a 3" block and it sat level. Now after a few years of using the truck the front settled a bit. Maybe .5"-.75"
When I put on the front springs I used ORD's greasable bushings and their HD shackles. At first I thought it rode rough then I removed the sway bar. Rides great. And I can still haul heavy loads.
I was concerned about weight capacity on the rear springs and so I kept the stock ones. Instead of blocks you can do the shackle flip and go for the smallest one. I'd say make sure you buy the HD rear shackles to handle the weight/stress.
Running 285/75R16 (33") tires on 16x8" steel wheels.
ThSlug
Maryland
Matthew
Thanks. That's a huge help. Sounds like I will have to deal with a bigger lift if I want HD springs.
Good to know about the sway bar. I will give it a shot. That's a lot cheaper than buying a lift kit!
Splandman
Crescent, OK
Scott
I have a Skyjacker 2 1/2 inch all spring lift. I don't think it rides all that rough. I'm also running 33 inch tires.
btrain04
