cstew47
- Feb 7, 2015
- colombia
- craig
- K5
I have done a lot of structural design work and I am very confident that you are ok with the structure that you built. Also, you have to understand that there are five available sizes of 3 inch channel. They are rated by lbs/ft of weight. It's difficult to identify which you have unless you can talk to the supplier. The lightest is 3.5 lbs/ft. 4.1lbs is also very common and is much stronger. What Bextreme said is very true. You are dealing with live load figures that will never equal the total weight at the weakest point.
