Lifted my truck today but have a problem is this right ?
TexasOutlaw87Cummins
santee
cody
k 30
5.9 cummins
I hope so I got the back in today and it's right I think :/ so I'm going to call them in the am and see what's up if they say there right then I'm going to have to see what I can do do you think there backwards ? I got the springs that move them a inch forward . And the little spring perch is in the back and the big ones up front and the off road design stickers in the back . So I don't know ill switch them around this week and see where I'm at . But now I gotta get drive shafts built and then it's finished !!
nvrenuf
Mobile, Al.
So did you try my suggestion?
As for them being installed backwards or not, only you can determine that. Off the shelf springs have centered pins but since these are custom with offset pins you'll have to get in there with a tape measure and figure that out.
santee
cody
k 30
5.9 cummins
Hey I just went to measure them . The old ones are 44-45 the ones on the truck are like 43 -44 so think I just need to tri to settle them !? I don't know I just think there backwards ...
santee
cody
k 30
5.9 cummins
No didn't get a chance today I put the rear in . But I'm going to talk to them tomorrow when I get home ill tri ...
nvrenuf
Mobile, Al.
As far as having them on backwards, that wont cause this problem because the overall length doesn't change. Having them backwards would just cause center pin location issues.
nvrenuf
Mobile, Al.
Also, it sounds like you're measuring eye to eye. To correctly measure the spring you need to measure along the arch of the spring.
elstm3
montana
lynn
V30 crew cab dually
6.2 twin turbo diesel
yea I stated that incorrectly nvrenuf is right the measurement is along the top leaf from bolt hole to bolt hole
I'd send those pictures to ORD and ask them what they want you to do. Whatever they measure out to be in length, it's not long enough IMHO.
8T6K5
AZ
L98 350 TPI
Does the front/rear brackets appear to be in OE spot...PO running 52's up front?
Front driveshaft is disconnected....axle moved, how does wheel sit in fender well??
8T6K5
AZ
L98 350 TPI
Wheel is way forward....
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
i think the springs may be for a 72 and down body style
definitly wrong springs
3dbello
