73c20jim
- Jun 11, 2018
- Tombstone, AZ
- Jim
- C20 2WD Custom Deluxe. C10 2WD Base Model
- 350 CID 195/260 HP Goodwrench crate, 400 CID 2bbl
It ain't hard once you know the magic.
THE MAGIC:
Remove shrouding around steering column to dash.
Place vent under the dash a little to the right of where it goes.
Push vent up under dash. It doesn't gothru anything. It just tucks under the dash.
Push vent to left guiding it over the parking brake rod.
Push vent to right guiding it on to hwere it connects to the system.
Install Shrouding.
There is one screw the connects the vent to the shrouding.
Your welcome.
Only took two hours to figure this out.
Then took it in and out a couple of times to check THE MAGIC.
Each time took 90 seconds.
THE MAGIC:
Install Shrouding.
Your welcome.
