Fuel Tank Filler hose
rdnether
Logansport, IN
Doug
All of those possibilities on a 78 GMC?
Thanks!
Skweegle89
Oklahoma
Do they sell extended filler hoses? The PO put this body lift on and now the neck is too short and just flops around in the fuel door. Takes 10 minutes to try to get the cap off so I can get gas.
MadOgre
NA
NA
NA
NA
NA
I would lift the tanks as well
rdnether
Logansport, IN
Doug
Here is a picture of my existing fuel filler neck. Can anyone identify the year? It does use a 1 3/8" hose.
yeol1
East TN
Joe
When I redid my tanks from my 79 i got new hoses from LMC truck. They where OEM replacements and fit perfectly.
highdesertrange
kalifornia
mike
k30
fyi gates makes a full line of the rubber gas fill hoses. can be bought at any parts store that sells gates. if the parts guy doesn't want to take the time to find it go to the gates website find it yourself and take the part # to your parts guy. btw you can do this for radiator hoses also. highdesertranger
roundhouse
atlanta ga
justin
77,78,79,80 ?
we have what I think is a 77 stepside,
with TBI, currently using a frame mounted pump
need to replace the tank anyway, and thought wed use a 87 tank with the built in pump
but im getting the feeling that the filler hoses are so different that we cant use the 87 tank?
MadOgre
NA
NA
NA
NA
NA
I would see if there is a difference in mounting the 87 fuel sender into the 73-79 tank
tgchevy77
so tx
tommy
I was looking for the same thing for my 77 c10. I was thinking of just building mine up from exhaust pipe. Don't know if that would work
MadOgre
NA
NA
NA
NA
NA
Thanks for all the help. I think it might be a different bed on it but I am not sure. If this is the case I'm guessing I will need to piece all this together?
Thanks
The fuel door opening is a 79'-83' style. I have both styles and it looks to me like the later 84-87 would retro but Im not sure as I have not actually tried it. But your fuel fill opening is definitely 79'-83'. In 84' it changed from the partial metal splash shield to a plastic splash shield that encased the entire opening.
firebane
Calgary, AB
Curtis
I just went there and checked and neither a 74 or a 76 pull a fuel filler hose for these trucks.
ajordan282
VA
Andrew
Here is the passenger side of the dual tank setup that is on my 83. Everything is how it came from the factory.
filler neck behind fuel door
factory hoses and metal piping (again I have 16 gallon tanks, not sure what a 20 gallon setup would look like)
Bringing this thread back from the dead...my apologies in advance for that!
@Boone83K10 are you aware of where I can get replacements for the metal sections of the filler neck and breather (shown in second pic above)? Driver and Passenger sides are both rusted, pin holes here and there. Its not clear to me that LMC or FillerNeckSupply.com has the right parts. I'll sandblast and weld them if I have to...but thats not ideal :)
I believe I have the exact same setup as you - 83 K10 Long Bed with dual 16gal tanks. Any advice appreciated!
jingle1
