Froze BBC
ajd89
Central Michigan
andrew
Ok maybe I'll get an answer here I posted in my build but no answer hoping someone will be able to help.
I've got a 91 454 out of a parts truck. Was told it ran when the truck was parked 4 years ago. And was told only has 80k on it. Odometer reads 30k. Got it home and it was stuck wouldn't budge. Put atf down the intake and the cylinders and after sitting for a couple of weeks it will roll all the way over! Yay! So now my question is I don't want to rebuilt it if I can help it do you think the rings and cylinder walls are ok? Should I do a compression check it or what? Hate to get it in a truck just to find out it need rebuilt
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I'd atleast pull the heads and visually inspect the cylinders. Then again if the rings were stuck they may not be in that good of shape literally.
ajd89
Central Michigan
andrew
Darn was hoping to avoid that lol but kind of was figuring.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Sorry man, like you said wouldn't want to get it in the truck and have it smoke like a freight train.
ajd89
Central Michigan
andrew
Can I just tell people it's a diesel?
Know anybody with a boroscope? They are a handy gizmo for a situation like this. Just stick the end in the spark plug hole and see whats on the little TV screen.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Yes and no you can see the bore but you won't see if the rings are "glued" to the pistons and lost their sealing properties. Not arguing just saying.
ajd89
Central Michigan
andrew
That thought had crossed my mind I can rent one from AutoZone for like a hundred and forty did that to make sure my 4.8 was a 4.8 once.
@Honky Kong jr
I can't do a compression check to make sure the Rings are holding? that would save me from buying head bolts and gaskets if they are okay
CSFJ
@Honky Kong jr
Hell, you can pic them up off ebay that will plug into your smart phone and display the picture in high def color for $20. One of the guys I work with picked one up last year just to see if it was worth a damn. Pretty impressive for the money spent.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
@Honky Kong jr
The oil rings being the smallest will stick the easiest. And a compression test isn't gonna tell you anything about them. If you do a compression test do a dry test and then a wet test.
87scotty
Central il
Andrew
V20
5.7 for now
try it and if she smokes like a chimney after a few hundred miles she needs a rebuild not that much work to drop it in and see
87scotty
Central il
Andrew
V20
5.7 for now
or build an engine stand would be kind of handy to have
Bhardiman1
