Front end alignment?
86suburbanNJ609
South Jersey
Aaron
Suburban
Truck is getting loose up front and also alot more play in the steering. It is a daily driver so my questions are is there anything.I can do myself to at least to identify the problem first.I'm kinda strapped and before I bring it to a shop I would like to give it a shot. Is there a forum on here that will walk me through I'd appreciate it thanks in advance.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Play in the steering as in you turn the wheel and it moves quite a bit before the steering box produces movement? Or is the steering box reacting to your steering wheel input, but the wheels don’t react immediately?
You’ll probably need two people, or you can put a crescent wrench on the steering shaft and turn it left to right while watching the arm on your steering box for movement. If your box seems tight and reactive, put the front end up on jack stands and start wiggling stuff. Also look for torn bushings on your leaf springs.
86suburbanNJ609
South Jersey
Aaron
Suburban
Bushings look like they've been replaced recently. Steering is slow.to catch up with steering wheel if that makes sense. Another thing that b**ch will pull you off the road in the rain if you ain't paying attention.
I just want it safe for the ole lady to drive it.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Right, you need to determine if the play is in the box, after the box or both. If you turn the wheel does the box react immediately? There is a shaft going in the back and an arm off the bottom. Does input and output happen equally or is there a delay?
86suburbanNJ609
South Jersey
Aaron
Suburban
On
Definitely a delay
86suburbanNJ609
South Jersey
Aaron
Suburban
Would the wear in the front tires have anything to do with something like that?
I have to rotate em soon just haven't had the time.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Maybe you need a new steering box
And it can be a combination or a wore gear box plus wore tie rods, pitman arm and idler arm too. Park it in the street with the front tire up against a curb. Then have someone inside the truck trying to turn the tire into the curb. Sorta as if trying to bounce the tire on the curb. While they're doing that, you need to be under it watching each and every component for excess travel, flex and play. If a part has flex or play, then it needs replaced.
86suburbanNJ609
South Jersey
Aaron
Suburban
Nice I appreciate
Thanks I appreciate the info I'll try that when I come home from fishing in the morning.
idahovette
Weiser Idaho
Perry
K20-K10
Sometimes the drag link ends loosen in the taper. Be sure to look at these ,too .Oh and please don't have the engine running while you're under it with someone at the wheel !!!
DaleP
Wrangell, Alaska
Dale
My right side tie rod end was very badly worn. At 45mph it got into a massive death wobble. 1/4 turn of the wheel in each direction. It was an exciting ride for a few moments!! Tie rod end fixed it and my box was fine.
mavtricks71
az
mike
I just did new Gear box from napa on my k10..... tighter steering again.
Obwonkonobe
AZ
Ethan
C10 custom deluxe
If you've never adjusted it before as well, there's a nut and bolt inside it on the top of the gearbox, that allows you to tighten up the steering. Its just a bandaid if you have other issues, but cant hurt. Just be sure to go in 1/8 to 1/4 inch increments on the center bolt, the nut is just used to lock it down
AzGeo
Start at the idler arm . That is the weak point on these front ends .
Stewy
Pacifi Northwest
Scott
k25
I use to work in a front end alignment shop and did quite a few checks and rebuilds on F- suspension / steering parts. Here is my recommendation.
While the truck is sitting idling, have a friend sit in the drivers seat and have turn the wheel back and forth in a short motion. Like from 12:30 to 11:30, back and forth. Not fast but not slow. Get on a creeper and slide underneath the truck and watch all of your steering components move. Your looking for bad / loose ends in every moving piece, including the steering box. You'll see it. If it's wore out, you can tell.
The steering gear boxes in these trucks were / are superior but eventually, over time, all of them wear out. A small / tiny amount of play is sufficient and can often be tightened up by the adjustment on top of the box. I believe there is a video of how to do that on this forum. Just search for it. But as they wear out, you ultimately need to replace the box.
Bhardiman1
