- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
Uhh yeah, with a Stage 2 kit and no 1-2 accumulator spring, you should be guaranteed a 2nd chirp when ever you want it, unless you can hook up the tires in which case, it should break your damn neck. Did you find the trick to the accumulator O ring? You don't put the O ring about the cover then put it on. You put the O ring its groove in the trans, then put the cover over that Oring then the retainer and you're good to go. Not done right, that is why the cover was fighting you.
