lol well i'm not sure if you mean it gets in the acc. pump hole or whatever, if so not sure if that's what is causing it. His just runs good, then it idles down low and won't run like it's plugged up and if I choke it the idle comes back up nice and smooth. Unchoke it drops down and barely runs, sometimes it don't run just dies. But when it's cleaen or not acting up/plugged up the idle screw and mixture are right on, around 800 rpm in park and 600 in gear. Revving and everything is fine, it just drops off on idle and tries to if not fully dies. I can choke it, rev it and let off the choke and get it cleared out and running better again. Has a new filter on it, but I think the crap is already in the carb.
